LincolNut's mishap
Moderator
Looks like Mike Wde had a little mishap moving this project truck around his shop. Glad you weren't hurt, Mikey.
Well here is really what happened. I have a two post lift and I had the Econoline about a 4 inches farther foward than I had had it before so I could open both doors and also lift the truck so I could work under the truck. I had to replace the freeze plugs and that is quite a prosses if in a 6 cyl motor in an Econoline Pickup. There is enough room in the shop for a car to go ALMOST as high as it needs to BUT not quite enough......The problem there was a couple of electric plugs that just did not clear the windshield as you can see.....It seems to be ONLY a 500 dollar Opp's or there abouts................
We must be related! That happens to me all the time. Mine usually involve blood and bandaids! Lol
You need to shrink about a foot, then you can stand upright while under the vehicles.😁
